Hmmm...I'll try.
1)remove large silver bolts at rear of side panel.
2)remove small allen bolt at the front inside rubber tab attachment.(black screw).
3)remove quickrivets(2)on that rubber piece attached to plastic inner part.
4)Pull rubber 'boot' forward and over plastic tab on side panel to clear the tab.BE CAREFUL not to snap that tab off.I use a thin allen key to get under the rubber lip and peel forward over the 'flange' on the sidecover tab where the screw goes through).You don't need to completely remove it 'over' that tab...just enough to allow the tab itself to move rearward when you start pulling back on the sidecover.
5)grasp rear part of side cover with left hand.Slide left hand under the sidecover and pull gently outward to clear the two projections in the sidecover.You'll feel em pull free as you pull this piece towards you...Rock downward to clear the upper edge tabs in the midfairing/tank cover.Don't overdo this.Just down far enough to clear the tank cover there.It will still be attached at the front of the sidecover/midfairing pocket(the four tines and 'plate').
6)Gently move the side cover up and down while pulling rearward with left hand,and right hand supporting and holding(pulling as well)at the front where it goes into the midfairing slot(s).Go easy with this.Rock and pull rearward at the same time.It'll come free..just might take a couple of tries though.
7)Battery cover is the black piece with the one silver large bolt in it.Remove bolt.Pop cover off(pulling towards you.It also has a projection on it(behind).
THIS is CRITICAL....when reinstalling the upper silver bolt in the sidecover and tank cover seam...DO NOT push that bolt in there.Insert it lightly to get it in the right spot..then turn carefully into the wellnut.DO NOT PUSH it into the wellnut(VERY lightly is okay).Turn and allow the bolt to start threading.Then continue tightening...without pushing with the allen key.That wellnut CAN pop free to the inside of the metal tab it's attached to.And into the airbox...trust me...you don't want that to happen.
When reinstalling the side cover..slide sidecover back into front pocket.At the same time,make sure the upper edge tab(s) are going under the lip(tank cover and midfairing)and that the front forward facing tab on the sidecover is sliding UNDER the rubber piece there.Once in place,push gently where the projections are at(use a bit of spit on the projections prior to reinstalling sidecover).It will pop onto those projections and be flat along the contour of the body panels.Recheck upper edge of sidecover to make sure the small tab is in the upper piece tab slot.
Reinstall quickrivets.Reinstall black small screw.Reinstall large silver bolt(lower one in sidecover)and give a final tighten to the upper wellnut bolt.
When reinstalling that rubber piece over the front tab..there's a flange on it(along the outside edge)...that sits 'on' the plastic fairing piece there..not tucked underneath it or 'inside' of it.Look how it's sitting on there(over the fairing piece) prior to removing with the sidecover installed.
The manual has about 5 steps to doing this...but they don't really explain the smaller details.They're assuming a tech is working on the bike..not the owner.It sounds complicated a bit how I described it...but after a try or two...you'll get it easily.
* Last updated by: Grn14 on 10/25/2015 @ 7:02 AM *
