I was wondering if anyone knew if it was possible (outside of reflashing the ECU) to change the fast-idle speed? I've installed a Akro 4-2-1 full system, PC5, ignition system, TRE and K&N air filter and set the normal idle to ~1,000RPM.
But, during start up it used to idle around 2,000RPM and is now hitting 2,500+ RPM which seems a bit high to me (1,500 is a lot more reasonable IMO). My main concern for wanting to do it is the same reason you don't jump on the gas when the bike is cold, cleaerences are still out and oil isn't flowing as well as it could/should.
