Thread: Question for double stackers
Created on: 07/29/16 09:05 PM
lee113
lee113's Gravatar
07/29/16 9:05 PM
I just installed Heli risers with GenMars stacked on top. The left bar set is solid, but I feel some movement in the right bar set. Not a lot of flex, but enough to make me a little uneasy. I secured them with 80 mm bolts sources from Fastenal.
Any advice?
Lee
Nastynotch
Nastynotch's Gravatar
RE: Question for double stackers
07/30/16 6:05 AM
You have slack somewhere. Start looking.
2013 ZX-14R SE
2 Wheel dyno works flash
Muzzys black stainless slips
V1 custom mounted
Zero Gravity DB screen
Yoshimura fender eliminator
Black powder coated wheels
lee113
lee113's Gravatar
07/30/16 9:25 AM
I'll pull it apart this afternoon.
Also, did you bend the front brake reservoir bracket or purchase an adjustable one? The clutch reservoir clears the fairing and windscreen, but there's no way the brake one will.
Thanks!!!
Lee
KINGY2
KINGY2's Gravatar
ST.JOHN'S NEWFOUNDLAND
08/03/16 11:07 AM
I just bent the brake res. bracket , no problems at full turn but it is very close.
I used 90mm stainless bolts.
Make sure everything is solid before riding !
* Last updated by: KINGY2 on 8/4/2016 @ 6:36 PM *
lee113
lee113's Gravatar
08/04/16 5:27 PM
To my surprise, both reservoirs clear the fairing and windscreen. The brake reservoir misses by about 2mm...??
Everything feels solid now that I've reseated everything before bolting it up.
KINGY2
KINGY2's Gravatar
08/04/16 6:38 PM
Glad you got it buttoned up !
doubleD
doubleD's Gravatar
08/09/16 1:57 PM
I used 2 GenMar spacers per side for 3.5 years. Flipped the Throttle cables, released the front Brake line and made new brackets for the Reservoirs. I added Zero Gravity Touring shield for more protection.
If I had long arms this setup would be enough, but I'm shrinking as I age. Convertibars now.
GTR27
08/09/16 11:14 PM
When you say flipped the throttle cables - do you mean took them off and swapped the cables? What about brake and clutch lines? I'm going to try one spacer first, but coming off a handlebar naked bike, might need two for commuting.
lee113
lee113's Gravatar
08/10/16 8:14 PM
All I did with my throttle cables was to loosen them and flip them 180 degrees so the cables are on the bottom of the handlebars, not the top.
doubleD
doubleD's Gravatar
09/08/16 8:55 PM
I flipped the throttle cable housing, drilled a new hole for the pin. Released the brake line from the triple tree.
Made new brackets for the reservoirs.
