Hey guys. Just wanting to know if anyone trusts the notches on the swingarm for alignment. I am using the laser method. Same idea as Romans posted before but instead of a mechanical its just a laser that shines down the length of the chain. I'm sure some of you use it. SO the laser is running down the top of the outside link all the way down the chain. Looks like a great alignment. But when you compare the notches they are off a noticeable difference. Also When I do a quick measurement from the scraping pegs on the bottom of the footpegs to a fixed location on the swingarm and even that shows off about .5cm. So although the measurements are showing off the laser if pretty dead on. Makes more sense to trust the laser but I wanna know what you guys think. Thanks!
Jack
