Ok guys, here is a mystery for you. So last year I was ripping up some back roads in 100+ degree texas heat. I hit a nice long straight and opened it up. All of a sudden she cuts out, I give it throttle and nothing. Pulled her over and and thought I might have accidentally tapped the run switch. Fired it up and it kept on running like a champ. Forward to this weekend, after replacing my coolant with engine ice, an old and filter change, some frame sliders and a USB charger wired to my battery. Im flying down the road and I give it some gas and I lose power. I give it a bit more gas and it surges forward! Eventually this got worse and worse until I had to slow down and she just died all together. I waited for a few minutes then fired it up and limped home. The issue came up maybe once more on the 30 minute ride back. Yesterday I took it out and tried to ride around at 6k rpm's and it did happen again just once but it never died.
My plan is to check the PCV connection and reload the brocks map. If that doesnt do it, and you guys dont have any suggestions its off to the stealer for a check up.
Any insight you guys can offer will be greatly appreciated it. This is on my 2010 ZX-14 SE.
