have an '06 with some 25000 miles on it. Last long haul trip the headlights suddenly would go dead ..then would come back on. As I finished the ride the turn signals began to fail to work... then both began flashing irractically at the same time.The bike became an ambulence with a buzzing sound coming from the relays at the headlights --which remain dead.
Replaced the battery ..checked the grounds..nuthing ..still the same. Have a PC3 +ignition module +tre..and everything has worked perfectly till last trip. It came on in stages. Ignition ( start up) and running is fine ..just all the lights do not work properly. Is this a relay problem ..a ground or a power problem somewhere???
Driving me nuts and I have to get the thing back on the road for a trip! Am NOT sending this thing tothe grease monkeys to further screw up for huge $$$.
any help will be greatly appreciated .
graeme
* Last updated by: painterdude on 3/25/2013 @ 8:58 AM *
