Hey scott...if ya look close at yer low beams...only those on...you'll see a line of different color going across horizontally(when she's illuminating a wall right there).Okay...to get those Verticals set right....get that line superimposed over the OTHER line that is most pronounced.You'll see what I mean.You can watch the beam angle either raise to the other,or vice versa.You want those two lines as ONE bright line going across the wall.Then they're set.You can drop or raise however you need to after that...mine are out a ways...the round part of the "beams" hitting about 15 feet out in front,and the rest of the illumination goes on for around 100 feet or so.Then,with the brights..it REALLY illuminates ahead.But when ya switch back to lows(like for an oncoming car)you won't have that dark spot right where ya need to see...like about 50,60 feet out.I found(good or not?)that I occasionally get "brighted" with my lows on at night.So.....I try to use my highs as much as possible,then when an oncoming car sees ya flip to lows,they automatically realize....yer on your lows.So that seems to limit their reaction.I just lowered mine an inch more...just for that reason.But I'm still getting plenty of good light out front with the lows.You can see where it hits the drivers as they come at ya.You don't want to be illuminating their driver's area inside the car.Gotta adjust lower if they're doing that.But not TOO low.They're projector beams,so the light isn't as wild as a regular lamp.It may look kinda "sweeping" off center,but the main lamp light is right at the center of that "circle" in front of your bike....however far out that is.Of course,moving them OUTWARDS is gonna affect the light going farther towards the oncoming cars,so ya gotta take that into consideration as well.I REALLY don't want to anger people,ya know.Mine are just about perfect now....but NOTHING like the factory settings.This is at about 20 feet out.You can see that the lows are barely illuminating anything above the camera lens,whereas the brights are doing quite well.These are not my present settings.These are TOO LOW for nightime riding.The cages don't see the full on blast from the projectors UNLESS they're adjusted straight into the driver's area.But the outer light can be quite intense also.So I've tried to reach a medium with mine....I think I've pretty much got it worked out now.Next night ride I'll see how other drivers react.As I said,I lowered them again yesterday about an inch.This pic I took with about a 3 foot height.The lows were useless at this setting.
You have to adjust,then ride at night to see the pattern of solid light going out.Once ya get the pattern set to about where ya want it,then it's pretty simple to micro adjust as you need to.But I'll tell ya...these new settings of mine are WAY different than the factory ones.There is no pat"turn three turns" type deal here.At one point,I had the left adjuster ALL THE WAY set to the bolt stop.Naturally,it needed to come down some....but not much.I was pretty surprised about that actually.Especially with the HID's.
1/4" knuckle,three extensions,10 mm socket.That works good for getting in there and adjusting easily.To adjust the inner(horizontal) lighting,run your extensions on the outside of the ram duct,up past the bar end(which is now fully right)(or left,depending which side yer doin).
Those two bolts however are OPPOSITES.So adjusting to the sides are going to be opposite each other(not like the Vertical,where BOTH turn the same way and adjust the same direction).If you turn the RIGHT lamp adjuster CLOCKWISE,your beam is going to move LEFT.As well as your HIGH BEAM.If you turn your LEFT lamp adjuster CLOCKWISE(yes,clockwise),your beam is going to move to the right,as well as your HIGH BEAM.
Course you have to remember....with your 10 K's,your lighting is going to be "somewhat"different,probably "less".However,the blast effect to oncoming cars will still be just as violent!So ya can't adjust too high to get the same lighting effect,but ya don't want ANY dark spots in front of your bike....at any area where you need to see if something's in the road at least 70 feet out.Mine is set at least to that.Nothing worse than dropping to lows for an oncoming cage,only to have the whole road in front of ya black.Especially in a curve!WoHooooo...fun times there!
* Last updated by: blue07 on 6/24/2010 @ 2:40 AM *
