Thread: slightly taller tire trick out the ABS?
Created on: 07/10/16 11:06 PM
CobraVIII
07/10/16 11:06 PM
Will a slightly taller tire only in the rear mess up the abs and traction control ?
Fantastic
Fantastic's Gravatar
RE: slightly taller tire trick out the ABS?
07/10/16 11:46 PM
No.
190/55 is overrated. 200/55 is where it is at.
darkarcher
darkarcher's Gravatar
Cincinnati, Ohio USA
07/11/16 6:24 AM
Agree with Fantastic from what I have read. 2012 and newer it will throw off your Speedo a bit because it uses the wheel speed sensor/ring and it will think the bike is going slower than it is due to the larger circumference. Mine is already a bit off so I say go for it. I will be doing a 200/50 or 55 next time depending on how things go. If I ugrade to Carrozzera's maybe I will get the 6.25 rim.
2020 on the way!!!!!!
