Gonna stick my neck out here...and ask anyway.Okay,when installing my Ohlins rear shock,I didn't realize the compression reservoir had to be pushed up through the swingarm hole BEFORE the shock was hooked up.Not knowing this...I installed the shock first...thinking the reservoir would fit through the spring/shock hole with the shock installed(the preload adjuster DID slide up through there with the shock installed).I 'thought' I could possibly turn the comp line a bit,so the unit and line would not be trying to go in there sitting next to each other...long story short,I loosened the banjo on the unit just a wee bit,to turn the line.I allowed a split second of fluid and pressure to escape out the banjo...but immediately tightened it back up...only a very small amount of fluid came out...not even an 1/8 of a teaspoon.Less than that...it was a quick 'mist'...that was all.Can anyone here tell me with certainty IF I've screwed up my new shock unit?Haven't been able to ride her yet...It was just a split second of misting and gas...nothing serious(I hope).Thanks in advance guys.....It actually CAN be turned,I just loosened it a shade too far....
