Got one for the books. 08 zx14 loses clutch lever feel any time you throw it on her in any gear.
Lever feels just like air has entered the system,in fact when i bleed it the system does have air in it.
Feel comes back and i can ride off like nothing is wrong. Here is the weird part. There is no sign of leak anywhere in system.I have replaced every part of the hydraulic system on the clutch,master cyl, twice. All new OEM.
I mean every part from m/cyl to slave even the push rod. Take it out ride easy and it runs fine, but poor it on her and after 1 or 2 gear changes same thing lose lever feel and clutch again as if the system went dry instantly.
I shift it without clutch or with clutch same deal, pull over, pump lever 3-4 times,bled at slave or m/cyl and feel comes back and air was present.
Ride off like never happened. I have measured/marked res fluid level and never lose enough to measure Except of course when i bled it. There is absolutely no wet,or damp spots at any point in/on system anywhere. Nothing!!!
Customer bought bike new in 09 and its always had this problem, and kaw was no help all thru warranty.
Guy was overseas 2 tours so bike sat but hes retired, now back to riding it and the problem persists!
The bike has stock levers, hell all stock except for brocks ex. I am at the point where honestly have no idea what the hell is failing.
I even pulled the clutch out of one of my 14's (Basket,inner, p-plate, pack, rod assembly) hell u get the idea.
How about it Hub, go deep son its one for your brand of brain speak,LOL. Seriously anyone ideas is appreciated .
Thanks, Bill.................
