Best deal I've seen on tires in a while. Just thought that I'd pass the link along.
http://www.zx-10r.net/forum/showthread.php?t=72660
The bt016's the best tires I've ever run... give 'em a try... you will like 'em!
Created on: 04/07/09 09:15 AM
DogoZX
Great Deal on bt016's
04/07/09 9:15 AM
gilberjj
DogoZX
RE: Great Deal on bt016's
04/08/09 1:48 AM
I know CG's deal was about $20 cheaper, but haven't seen that deal since December (even then the stones were gone FAST and they subbed Pirellis but not the comparable C3's), and who knows if or when they'll have that deal again. Also, they never offered a deal on the 190/55/17.
Rook, you'd save about $50-$60 plus shipping compared to most listed prices for these tires. Since I seem to order 2-3 sets of tires at a time, that's quite a bit of $$$.
These things are way stickier than the stockers, so you do sacrafice some longevity. For me, however, the wear was much more even edge to center than it was with the stockers. Also, my front and rear wore out at the same rate. Which I really like since I've always replaced them both at the same time anyway.
* Last updated by: DogoZX on 4/8/2009 @ 1:52 AM *
04/08/09 8:52 AM
Thanks, Dogo. I'm getting 'em. I'll run the stockers bald and have the bt016's ready to replace.
Would you please explain the difference between the 180 and the 190? It has to do with the fatness of the tire, correct? Has some effect on cornering, does it?
* Last updated by: Rook on 4/8/2009 @ 8:58 AM *
DogoZX
04/08/09 10:00 AM
Yeah Rook, the 180 is skinnier, which would help diving into corners, but sacrafice some of the contact patch. Personally. I woould not run the 180.
The 190/55 has a taller profile, which would help diving into corners, without sacraficing the contact patch. I've never run a 190/55, but I know Mass does and loves it. Catch is the taller rear will throw off your speedo. I have a healer so no worries.
I thought they had the 190/50, our stock size, listed yesterday. I dunno, we hit 70 degrees here yesterday so my focus was elsewhere. I asked how much for the 190/50 on that thread but they usually respond with PM's. I'll post the price here if and when they get back to me.
DogoZX
04/08/09 10:07 AM
A better deal!
https://www.cyclesector.com/ProductDetails.asp?ProductCode=BSTONE-BT016-SET
DogoZX
04/08/09 11:00 AM
$265 shipped on the 190/50/17 set on the first link.
$240 shipped on the second!
kawnow
04/08/09 1:23 PM
"I've never run a 190/55, but I know Mass does and loves it. Catch is the taller rear will throw off your speedo."
These speedos are 8 percent fast anyway so a taller tire would work to correct the speedo some.
* Last updated by: kawnow on 4/8/2009 @ 1:23 PM *
faz
DogoZX
04/08/09 4:00 PM
Good call!
masszx14
04/08/09 5:37 PM
This is my rear with a 190/55 Pilot Powers 2 CT... not really a Bridgestone guy.
The 55 is around 10 mm taller than the 50 in the 190 width- gives you a better lean
angle and a large contact surface while leaned.
Just add a tooth on the rear to compensate for it. Or if you run
a 16 front, you might actually be able to keep it on two wheels.
* Last updated by: masszx14 on 4/8/2009 @ 5:40 PM *
masszx14
04/08/09 9:05 PM
Thanks all. ^^I can see the Pilot Power 190/55s have a rounded top which transitions into a flat side tread. Makes sense. Don't know if I'd like to lean it quite that hard but nice to know I have plenty of rubber on the ground if I did. IMO, the typical 180 degree round tire tread like on the stocks looks better. Do the bto16 190/55s have the flat side tread, or are they round across the tread?
04/09/09 5:46 AM
A better deal!
Don't forget to add $15 for the 50 profile and $25 for the 55 profile. Free shipping is nice, though!
CycleJunkie
04/09/09 6:38 AM
Here's a diagram of the differences:
A short article concerning these questions:
http://www.sportrider.com/tech/tires/146_0302_rear_motorcycle_tire/index.html
DogoZX
04/09/09 10:27 AM
I did! Yesterday they were $225 (+$15 or $25).
They raised the price!
Suckers! That's what I get fo not just ordering immediately.
Thanks for the link, Junkie.
Wish they said what model of each brand they were testing though.
* Last updated by: DogoZX on 4/9/2009 @ 10:27 AM *
gilberjj
reevesmreeves
04/10/09 6:56 AM
jorgen, you can't go wrong with either tire. i've got the 190/55 bto16 on the 14 and i've got the 180/55 on my 636. the roadsmart is probably going to last longer than the bridestone, but for corner carving the winner would be the bto!
i used bikebandit.com because they do have the best prices and i don't have to pay their shipping fees :)
* Last updated by: reevesmreeves on 4/10/2009 @ 6:58 AM *
DogoZX
04/10/09 9:20 AM
You never loose when it comes to BTO!!!
http://www.youtube.com/watch?v=lJmBPCYt5LY
* Last updated by: DogoZX on 4/10/2009 @ 9:21 AM *
masszx14
06/02/09 1:17 PM
June 02, 2009 - Still going for the $268, free shipping price!!Just ordered a set of BTO-16s from Superbikessupply (1-828-252-2280) in North Carolina. He had to order a rear 190/55 for me but they still both should be here middle of next week.
Thanks for the tip, Dogo.
DogoZX
06/02/09 1:37 PM
No problem.
Superbike Supply is top notch!
Tip: tell 'em you're a member of zx10r.net (if ya don't wanna lie, just sign up, there's a zx14 sub-forum over there) and they'll give you their best pricing on everything.
b00fa
06/02/09 8:53 PM
for the Canadian contingent on this site if your looking for tires Pete's superbike in Quebec has the best prices you can pickup the bt016's delivered for about $300 front and rear plus other name brands just do a search for Pete's Superbike and you will find there site
