So ever since the obligatory 1st service, I get a clunk in the front end upon hard braking - classic "stem nut needs tightening" sound.
Well, I'm lazy, didn't get to it until yesterday. Take off the bars and top clamp, lock nut/washer - damn if it doesn't want to turn at all. Don't have the proper spanner tool, so was using a bronze drift. So the nut is some sort of shit metal (or maybe alum) since it actually marred up a tiny bit - whatever, I did get it to tighten about maybe 3 degrees.
Here's the dilemma: get the top triple clamp (BTW, it's not a f'n 'tree', it's a clamp, even though the manual calls it a cover) on the forks, slide down and what the? Stem does NOT line up. First time I've ever seen that, and I've had plenty of front ends apart before. My guess is the bottom triple bolts need to be loosened, then maybe get the play needed to get the stem to align.
Weird - and no, I don't do alot of hard-landing wheelies - or better put, I have yet to land one hard.
Will find out what's up later after getting home from work.
Oh yeah - 2012 14R
* Last updated by: ZRXDarryl on 9/1/2012 @ 9:59 AM *
