Thread: Qs? about lowering
Created on: 03/29/14 04:44 AM
donnymoss1977
Qs? about lowering
03/29/14 4:44 AM
If i use a lowering strap to lower the front in of my 2012 zx14R, is it as reliable as the links? And is there any long term effects that would harm my bike? I know cheaper is not always best.
Nastynotch
Nastynotch's Gravatar
RE: Qs? about lowering
03/29/14 5:30 AM
Lowering straps should only be used at the track to limit suspension travel. If your asking about street use, then no it's not a good idea because you would render your front suspension useless. You need full suspension travel on the street for safe handling.
2013 ZX-14R SE
2 Wheel dyno works flash
Muzzys black stainless slips
V1 custom mounted
Zero Gravity DB screen
Yoshimura fender eliminator
Black powder coated wheels
thebiglebowski
03/29/14 5:53 AM
the links dont lower the front anyway, links drop the rear. front you need to raise the fork tubes up through the triple tree ( free and easy way ) or have lowering blocks put in, they also can do new springs in the front to lower it.
2013 zx14r black/green SE
