If you're worried about o-rings....IF they're failing....look on your rim,chain side.See any "dust like" oil spots on there?Maybe reddish,probably grey.Wipe one off with your finger.Feels like graphite?That'd be yer link lube slippin past the rings.If she's doin that....chain time!(IMO)
If you've got an X-RING chain,the rings are gonna have a "flat" spot along the outside(exposed)surface(take one out,you'll see the flattish profile of the ring...not the same as an O-ring).The TINY x-seals can begin to separate from the seal itself.That may be what you were seeing sticking out.That in itself...IMO....doesn't indicate a replacement just yet.But I'd watch for the "grey spots" on the rim.THAT will definitely tell ya they're failing.If ya lube yer chain....it may be a bit more difficult to recognize the link lube from the chain lube...but you can if you look closely.Just thought this might help a bit.Everyone does things different.Don't mean to jack someone's thread here...you guys know that I'm sureHUB... .
If they're failing severely,yer gonna see several areas on your rim that have splash marks on it,probably grouped together.When I first noticed mine, I thought "wth is this shi%?I haven't lubed my chain recently,so what's THIS?"THEN,after looking around there,I noticed the ring pieces sticking out...corresponding with where the spots were at on the rim. I don't need anyone to tell me where the bear shit in the buckwheat
NOW...to Kawasaki Design.Wouldn't it be interesting IF those designers fashioned those wheel spokes to be angled for pulling air in and across those rims?Imagine how EASY it would be for the average Joe to discover WHEN his x-ring chain is beginning to fail?Hmmmmm.....(course,the front would need to look appropriate to the rear,so no biggie there.They're quite stylish the way they are!)
* Last updated by: blue07 on 1/19/2011 @ 12:57 PM *
