ZX14
Created on: 10/26/09 04:50 PM
NC2VA
hercsz
GSIG
masszx14
RE: My Toyz
10/29/09 10:21 PM
The tires are mostly other peoples. I have a No-Mar tire Changer so this place gets a few piled up every so often.
Blue it is lowered a little bit. What I hate is a center stand will not fit with the links. I will take the stock set of bones and have them cut/welded to the same length as the lowering links.
KAK
RE: My Toyz
11/26/09 12:33 PM
Nice bikes. Which is your favorite?
About the bar kit on your 14, any long term issues about the wiring harness being a bit tight or rubbing?
Clutch fluid line OK?
I'm thinking about the bar kit but would appreciate any opinions. Did you measure how much it changed the height and reach?
* Last updated by: KAK on 11/26/2009 @ 12:35 PM *
RE: My Toyz
11/28/09 8:38 PM
Hi Kak, the bars give a lot more up-right position than the Genmars could even get close to. The wiring is no problem, kit gives longer lines for the front brakes, clutch line gets a bracket undone from the frame for the length, throttle cables go to the bottom instead of the top and you get brackets for the clutch/brake fluid holder thingies.
I added the poor mans cruise control (throttle-meister), C14 seat and some Buell pegs so now it is more comfy and I ride it more.
Later == Bobby
masszx14
RE: My Toyz
12/20/09 3:00 PM
I just added another one. Did an almost ground up build for a friend over a 5 year period. Started out with a 2000 ZRX1100 and did the header/jet kit then 1109 kit then cams then 7 over arm then ported head then ZX11 brain/rotor and who can remember what was done inbetween them I do not know.
Joe wrecked a 4 wheeler in his yard and broke his right wrist. Even tho he is somewhat over it he still cannot grip tight enuf to hold a throttle in place or twist enuf to open throttle all the way. He got aggrivated and gave me a deal I could not refuse.
What sucks is his 1100 is faster than my 1200 with almost the same build except the 1200 is still a standard bore but with 12.5 pistons.
kawnow
RE: My Toyz
12/20/09 11:40 PM
Hey Lytnin I got a question about the bikes. I know someone who has a ZREX and is considering a 14 but likes the Z for long rides. He is not real tall how would you rate the bikes compared? Might be a tough question. Also how do the ZREX bikes accelerate compared to the 14 are they more wheelie prone on acceleration?
RE: My Toyz
12/28/09 11:37 AM
Sorry for the late reply but for comfort the REX is hands down but needs improvements such as a seat (Corbin is my choice), front sliders to give the legs a rest on the long trips and 1 inch risers (cheap) help out but not really a needed item.
