After 40,000 miles and no maintence on the suspension - I decided to go whole hog on the suspension upgrades.
Penske 8983 and Traxxion Dynamics AK-20 cartidges. Went with the Penske over the Ohlins because it was less expensive, which allowed me to spend more the forks and get the AK-20. Besides - I doubt that I would ever be able to tell the difference between the two shocks. Either one is a major upgrade from stock.
Had Dean of D2 Cycles in Liberty, Mo order and install the bits and pieces.
Huge improvement. I had lowered the triple on the fork tubes to get more weight on the front end, but with an adustable shock, Dean set the triple back to almost factory specs and used the shock to raise the rear end. Now the bike sits much taller. A side benefit of this is that the bike runs a cooler since the lowered front end had been blocking air flow to the radiator.
Took the bike for a short ride and it feels like a different bike. More feeling and thus confidence in the front end. On the brakes, the fork doesn't blow right through the stroke. The side to side tranistions are WAY easier and I can get on the gas sooner coming out of the corners.
All in all - a huge improvement and I won't wait 40,000 miles to get the suspension serviced this time.
