Txn,
Look at that chain photo. Set your eyes in the middle of the two middle link plates. Look straight up. Now, look at the hook caused by the thrust side. Look at the coast side of the one tooth. Look at how you have the air gap showing on the pull back in the other pic. See how the chain pins wear so that pull extends away from the sprocket teeth?
There are two examples.
1. As lame and as simple as friction can be shown, rub both hands together. Ask yourself, which hand stayed cool?
2. Second example is, look at the link roller to tooth groove. Which did not wear out as if saying, which part stayed cool so as no wear happened?
You can't. Wear 1 equals out wear 2 in the friction dept. So, ask yourself if they equally wore out, you'd lay a new part over an old part? No. You change new with new.
Here is the next example.
a. We set a wear pattern from day one out the dealer floor. This causes a single even wear pattern: not to be disturbed.
b. The second part is if you change tires for the first time, do not key in the cam sprocket to chain wear, as if you pulled the wheel, did not mark the tooth to link wear pattern, you now cause a new wear pattern...
c. ... High spots in the chain sprockets I think?... You do not key back in the link to tooth. I think the chain's pins receive the same go-around-wear, but the teeth on the sprocket, they receive the thrust-wear-pattern not as in proportion to the pin's, but you moved the sprocket location for argument sake, from 12 to 6 o'clock. This sprocket is not fixed perfectly lined up. So that sprocket carrier rubber is going to move with the thrust and cause a wear @ 12, 12 being how the sprocket was bolted up and locked higher from center. You install the carrier or say you never removed the carrier, it still says, I am no longer lined up with my original position from the dealer's drive.
d. Dealer may neglect the chain adjust, may have it too tight when it is adjusted. So the trick here along with the keying-in is to run a loose chain upon break-in of the new sprockets and chain.
e. So if book says between 1.3 ~ 1.5" slack, you run 1.8" slop for break-in.
f. After chain break-in: The tighter the chain, the less missed shifts, and too, a cleaner, more exacting shift.
