Thread: REAR AXLE NUT BOUND UP HELP
Created on: 03/27/15 02:07 PM
RE: REAR AXLE NUT BOUND UP HELP
04/08/15 5:28 PM
I used to go a little loose on the axle nut (as is my usual practice with most torque specs). The torque might have something to with compression on the wheel bearings or the legs of the swing arm. My rear axle nut is only is only torqued to 50 ft lbs with the Carrazzeria rim and bearings. CZ recommends using half the OEM torque spec for the rear axle.
darryle
darryle's Gravatar
04/09/15 5:59 AM
Don't know if this is true or not,but I have read you should reduce torque settings by as much as 25% on lubed bolts
danfzx14
danfzx14's Gravatar
04/09/15 6:37 AM
What size reusable cotter pin goes on the rear axle?
http://www.mcmaster.com/#cotter-pins/=wocwm3
* Last updated by: danfzx14 on 4/9/2015 @ 6:38 AM *
08 Midnight Sapphire Blue ZX14, Ceramic Coated Brocks CT MEG, PC III USB w/Brocks Street Map, Flies Out/Blocked PAIR, Penske 8983 Shock, Penske Fork Piston Kit w/GMD Computrak Springs, Scotts Rotary Steering Damper, Heal Tech Quick Shifter, Spiegler Stainless Steel Brake/Clutch Lines (Translucent Blue w/Red Banjos) All w/Speed Bleeders, EBC HH Pads Front & Rear, Pyramid Carbon Fiber Hugger, Bestem Carbon Fiber Front Fender, Zero Gravity Double Bubble Dark Smoke Shield, Metzeler Sportec M7RR, Battery Tender BTL14A240C Lithium Battery, Stock Air Filter w/Steel Screen Removed, Competition Werkes Slash Cut Aluminum Footpegs, Moto Fab Fender Eliminator, Supply N Demand Frame Sliders, Tank Bra, Pit Bull Swingarm Spools, Gold Plug Magnetic Oil Drain Plug, Moto Bolts (Kawasaki/Black & Chrome) License Plate Bolts, Moto Caps (Kawasaki/Black & Chrome) Valve Stem Covers
