this is pasted from brocks website:
STEP 10: REMOVE THE STOCK HEADER
using a
No. 6 hex the back wrench.
ratchet place with
release bolt.
from the
ASSEMBLY:
The procedure described below does not require removal of the radiator. However, the fit is tight and care should be taken to avoid damage to the radiator.
• Remove the header nuts using a ratchet with 12mm socket. extension will allow easier access to the header bolts. There bolts per header. Once the bolts are removed do not allow the flange to fall and contact the radiator. Carefully move the
a position away from the radiator.
• Once all bolts are removed, carefully remove the header from engine. Avoid contact with the radiator.
