I ordered a OEM centerstand for my 2012 14R back in November. The stand has been on a national backorder ever since the 14R was announced.
I telephoned Kawasaki this afternoon to find information about the stand, P/N 99994-0343, and was told that because the centerstand is installed on the 14R in certain markets (Asia) that they won't be stocking the part in the North American warehouses until their supply chain is filled.
They expected the centerstands to ship to the warehouses in N.A. by the end of February and then expected to start filling orders within two weeks of receipt.
So I will hopefully have my centerstand by the middle of March.
As for the difficulty of installation - Piece of cake. For the 14R you remove the right exhaust cannister **, remove the aft lower fairing and mount (I never installed my fairing in anticipation of the stand), and bolt the centerstand to the existing frame lugs. You install a bracket with a nipple to attach the spring to and it's already plumbed for all of this. Stick the cannister back on and go riding!!
**For the right exhaust cannister on the 2012 model, it was very simple. Loosen the constriction clamp underneath the engine until the clamp is free to rotate. Loosen the two bolts that attach the cannister to the frame - one located just behind the rear brake pedal and one at the passenger footpeg bracket. Remove the forward bolt but leave the rear bolt at the passenger pegs intact until you're ready to pull the cannister off. This way nothing will dangle and get bent or nicked. When you're ready, remove the rear bolt while holding the cannister and then gently twist the cannister as you pull it rearward. You'll feel if it is binding at the header pipe collector so just work it gently. I have had no issues with the gasket coming loose if you don't bind anything.
Good Luck. The 2011 model has a different part number for the stand than does the 2012 model but I don't think there's much difference in the procedures.
* Last updated by: Fowvay on 2/21/2012 @ 6:08 PM *
2012 ZX-14R Green
