... and I assume keeps the lube inside as you roll the chain through it. How do you mean that?
How do you cross over that creek but to send pressure lube back to that middle connect ring. How you going to do that? If you think you are going to jam spray...
... Down the middle if you have a rubber o-ring at the end.
Say there is no o-ring in place. I would think, one would have to remove the chain, lay the chain on either link side, soak as to raise the bubble of air to the top so the link does not lay horizontal, and have two sides fill up is lock the bubble in the middle kind of lube.
How can an auto lube run around the chain and create a pressure to lube the pin's center? I wanna see that trick. We are stuck waiting for the chain to wear out eventually. And if you think about the wear factor, the chain only moves around the chain about half way around the pin. If you ever pulled an old worn master link from a chain, you can see the rolling over the sprockets just crunch away the one side of the pin. Once that occurs over and over the sprocket teeth, you can see how the chain will stretch uniformly apart from pin to pin. Thus, the critical measurement known as your, "serviceable limit" is wear you find out how much longer you can waste lube keeping the noise down, having the outside rollers crash into a film of lube.
Why? Did you come across a post, Stephen giving me a ration'O'sheet? Sheet down is hold a chair under me I about fell back, Stephen mentions he would not question me, I'm sending along a tip is proof positive, after 10K miles, time that link to tooth with each tire change, then lube with wheel bearing grease with a tooth brush and forget about cleaning it.
The grit will cling no matter where you ride. My cleaning is to wear a glove, then squeeze what I over brushed with, meaning, this picks what grit is there on the chain. The grease moving the grit is now suspended in the 'over-grease' that is about to fling off and pepper my rear wheel in a few outings.
My point is, I have that camera picking up a smooth running chain. Do I think the chain runs that smooth re-timing the chain back to it's original position? I'll let you be the judge of that. High ho, eye owe, how low can my chain go...? <<<
