Thread: Cat in my headers
Created on: 10/03/19 12:53 AM
Maddy
Maddy's Gravatar
Cat in my headers
10/03/19 12:53 AM
Hi Guys, thanks in advance for reading.
Is there a catalytic converter in my header pipes or any other restrictions ?
The headers are the ones it came with.
Thanks lots, lost with out you's
Maddy
* Last updated by: Maddy on 10/3/2019 @ 12:54 AM *
RE: Cat in my headers
10/03/19 9:20 AM
I know there is not on my BBW 2014 so guessing 2013 is the same
10/03/19 11:08 AM
I'm kinda/pretty sure....
06 - 11 = in header/collector
12 - 15 = in slip ons
16+ = 3 way, in both headers and slip ons
On my 12, in slip ons only.
motoman97034
10/05/19 11:23 AM
I dunno if there's a Cat in your Headers...
Better check your Pussy!
(Sorry, couldn't resist!)
2016 SE ABS Guhl Flash/Map, Yosh R-77 4-1.
10/05/19 11:33 AM
the 2013 does not have cats in the headers.Only in the muffler.It does have a couple of flow vanes welded in inside on the collector area.These do not affect performance in a negative way.If you remove the muffler you will see the cat material right there at the fitting of the muffler piece.
* Last updated by: Grn14 on 10/5/2019 @ 11:35 AM *
Maddy
Maddy's Gravatar
10/07/19 7:00 AM
Thank you
Piken and Grn14
