Ive been noticing more and more vibration since my new tires were installed. or at least in the last 6-8 weeks. I thought maybe It was due for a carb synch, the alisyn 0-20 oil, or the plugs being past due were the problem.
I changed the oil, same issue. Then I finally got around to buying another go-cruise throttle lock. This way I could really hold the rpm's the same on smooth pavement and see where the vibe was coming from. SOB, back and forth twitch in the bars. WTF. new tire this spring, only has 3K miles on it. looks ok though.
Time to check the balance, so I pull it and have my friend use his balance kit. Sure enough, its off, but does take the same 1.5oz of weight. the shop that put it on, may have mis-balanced it. OR the tire slipped on the rim. but I doubt that.
the wheel also has a very tiny twitch in it side to side. After reinstalling the properly balanced wheel/tire 70% of the vibration I felt was gone. There is still some twitch in the bars I can see if I let go, but I cant be sure I can actually feel it. and it may even have been the road, I was in town and every concrete slab may have been causing it.
All in all, I'm happy it was an easy fix. So, check the simple stuff first.
