Guys, I need a little advice please. Not sure what to try next:
I put in the CC Drag pack fibers, Metals & springs.... Worked Well for 200 miles then noticed what I thought was slipping and realized that my clutch lever was not fully releasing so the clutch was not engaging 100%. I have Pazzo levers and cleaned & lubed the lever and housing then re-assembled. Is there any way to put a little more spring in the lever? about 1 month ago I changed all the brake & clutch fluid 100% with fresh Dot4... Old fluid was murky after 3 years and 4K miles on it. I do ride the bike very hard and try to keep up on all the maintenance.
