Posted in my other thread, but could really use a response ASAP as to whether or not I can ride in about 2 hours:
Did a full oil change with filter, re-filled with a 4-quart jug, idled bike for a few minutes, blipped the throttle a few times, checked the oil level the next day, oil reads too high, right at the top of the sight window. Decided to remove some oil.
Removed a little oil, checked level, then a little more, checked level, then a little more, checked level ... ended up removing almost an entire quart ... didn't measure it, but it's at least 3/4 of a quart. And even then it's still up at the high mark.
Is something wrong here? OK to ride it with only about 3.2 quarts?
Thank you ...
