After months of waiting, I finally got the new '22 to replace my fabulous '12 with 86K miles. As great as the old bike handled, what a difference with new suspension. I mirrored the suspension settings from the old bike and then made some adjustments while on a 300+ mile shake down ride. The handling is superb, especially with the BST wheels from the old bike.
Brock's CT 4-1 titanium pipe is already installed, along with a flash. The bike made 208hp. I was expecting a little more because the dyno will "read" a little higher with the carbon wheels. However, the bike only had 600 miles so it should pick up a few more hp over the next few thousand miles.
Blais Cycle in Dania, FL has been taking care of my biker for over 30 years and did the flash. The old bike fueled perfectly with their flash. I do have a small issue on the new one. Throttle response and roll on are superb. However, when coming off the clutch in first gear, at very light throttle, there is a bit of a hesitation/bog. Same thing in 2nd at low speed getting back on the throttle lightly after closed throttle. Also, fuel mileage sucks. On the old bike, between 65 and 85 mph, I was consistently getting 38-50 mpg according to the display. The new bike, 33-38.
We went back into the map and leaned out the "cruise" area of the map, as well as the the first 10% throttle, both of which were rich. It's definitely better, but the hesitation is still there. Fuel mileage is a little better.
I don't know why the old bike was so much better. Same tuner. Perhaps the current ECU. We tuned out O2 sensor, which Brock's recommends when tuning for fuel.
So, to the expert tuners out there, since I believe that the O2 sensor is closed loop, what about reinstalling the O2 sensor and going back to factory settings ONLY for small throttle opening and cruising at 3-5K rpm in 6th gear? Or should I leave the O2 "turned off" and keep playing with low speed.
If I have to live with it, it'
s no big deal because you can ride through it by using more throttle off the clutch in 1st gear.
All in all, a fabulous bike. But we all know that. The new Busa? Definitely more advanced, and maybe refined. But the motor. That 1441cc monster engine can't be beat.
Thanks for any help, and feel free to ask me anything about the '22.
