Thread: Mirror Block Off Plates
Created on: 02/28/18 02:39 PM
danfzx14
danfzx14's Gravatar
02/28/18 2:39 PM
Does anyone have any recommendations for Mirror Block Off Plates? I am reluctantly contemplating removing mine because my wife's new SUV is making it so I have to fold the mirrors in every time I take the bike in or out of the garage. I Really like the Brocks carbon fiber ones but would like to here from anyone who has done this to there bike. Thanks!!!!
08 Midnight Sapphire Blue ZX14, Ceramic Coated Brocks CT MEG, PC III USB w/Brocks Street Map, Flies Out/Blocked PAIR, Penske 8983 Shock, Penske Fork Piston Kit w/GMD Computrak Springs, Scotts Rotary Steering Damper, Heal Tech Quick Shifter, Spiegler Stainless Steel Brake/Clutch Lines (Translucent Blue w/Red Banjos) All w/Speed Bleeders, EBC HH Pads Front & Rear, Pyramid Carbon Fiber Hugger, Bestem Carbon Fiber Front Fender, Zero Gravity Double Bubble Dark Smoke Shield, Metzeler Sportec M7RR, Battery Tender BTL14A240C Lithium Battery, Stock Air Filter w/Steel Screen Removed, Competition Werkes Slash Cut Aluminum Footpegs, Moto Fab Fender Eliminator, Supply N Demand Frame Sliders, Tank Bra, Pit Bull Swingarm Spools, Gold Plug Magnetic Oil Drain Plug, Moto Bolts (Kawasaki/Black & Chrome) License Plate Bolts, Moto Caps (Kawasaki/Black & Chrome) Valve Stem Covers
RE: Mirror Block Off Plates
02/28/18 3:40 PM
I bought Vortex years ago. They have worked just fine but one of the studs broke off when I tried removing the nut which was not tight at all (in plastic, be careful with torque) but it was blue LockTited. I till am using it. The other studs have held just fine.
Get a cheap bar end mirror. It may be hard to fit one on the throttle side side. It was with my current setup but I got it to work. I don't recomend expensive bar end mirrors like CRG. The cheap knockoffs have just as good of glass and if you get one with two pivot points, it will adjust as much a san $80 CRG plus you might get two under $15. The only think that is better about my CRGs is that they can go to a higher speed without folding back from the wind. This not an issue at legal speeds and folding the mirror back for speed runs is not a bad idea anyway.
Cuff
Cuff's Gravatar
03/03/18 10:48 PM
I have two sets of these. One drilled and tapped for Ram mounts and one for show. Never an issue even with a camera on.
https://www.amazon.com/Motorcycle-Mirror-2006-2009-Kawasaki-ZX-14R/dp/B00RW3EJBO/ref=sr_1_2?s=automotive&ie=UTF8&qid=1520142364&sr=1-2&keywords=zx14+mirror+block+off+plates&dpID=512ZZrvnfxL&preST=_SY300_QL70_&dpSrc=srch
Blkcasper
Blkcasper's Gravatar
03/16/18 11:56 PM
There are a number of block off plates on ebay and amazon. Any year zx14 will work ass the mounting holes are the same for all years. i have the black ingraved st and a chrome engraved set. just make sure you use locktite on the bolt that goes into the block off base. I also have the exaghust hanger plugs, There a nice touch to cover up the open holes if you remove the stock exaghust
Your text to link here...
* Last updated by: Blkcasper on 3/16/2018 @ 11:59 PM *
Luvin My ZX14R'S.
