Has anyone used 3m emblem and trim adhesive? I want to replace my tank protector. Bought a tube of this but it says on the label that it can damage some paints and finishes. Was wondering if anyone used it before.
Created on: 06/14/13 04:38 PM
jmartin724
Neilp
RE: Tank Pad adhesives
06/16/13 12:52 AM
I removed mine in about 1/2 an hour using only heat from a hair dryer & some metho!
Don't really want to do it again though.
Neil
jmartin724
06/17/13 9:10 PM
I have a 2011. No stock tank pad. I wish I could get my hands on one. It's strong stuff. It would've held it on for a long time. Didn't damage the paint, however it's messy and hard to handle on a tank pad. It has to set for 12 hours, so I had to tape it down. The stuff is basically like plastic model glue. It was too hard to clean up the stuff that squeezed out around the edges and it just wasn't a clean job. I pulled it off and now have to scrape it off bit by bit with a plastic decal remover I suppose. GooGone didn't touch it and im afraid to use anything else. Live and learn I guess. At least I didn't mess up the paint.
omega2k
06/28/13 2:05 PM
I removed the badges on my VTX, was held on with the same $hit. I used a hair dryer, goo gone and WD40. No ill after effects. It took me about an hour to do one on each side of my tank and got a mean blister in the process. Picking off the lil pieces sucked butt, but it was worth it.
I keep kicking around the idea of swapping tank protectors as well, but it works and I cant see it when my junks on it anyway LOL
