Thread: Standard ZX14R Brake caliper size?
Created on: 05/16/17 08:24 AM
shawnturner
05/16/17 8:24 AM
Problem: I ordered Ohlins FGRT207 forks for my 2016 SE that comes with Brembo 100mm calipers. The Ohlins forks have 108mm size calipers mounts, so to make the forks work I ordered some Brembo GP4-RS calipers for the new Ohlins forks but i need to order spacers to mount the calipers. At this point I am assuming the non SE 14r calipers are 108mm and when ordering spacers for the calipers it would be for the standard and not special edition model. Can anyone confirm that 2012+ non special edition 14r's have 108mm calipers with 310mm rotors? Or if anyone has mounted Brembo calipers to there bike can they confirm if the spacers are 13mm spacers?
Appreciate the help!
I didn't find the right solution from the Internet.
References http://www.zx14ninjaforum.com/messages.cfm?threadid=8130BF65-1B78-59F6-0217A1EAF1B5FCCF
Explainer Video Example
RE: Standard ZX14R Brake caliper size?
05/16/17 7:37 PM
There was just a thread on here where the guy had exactly the same issue and he figured it out. This was like 5 days ago. Search or else this member will probably post here soon.
...unless that guy was you?
05/16/17 8:16 PM
something weird is going on here. Crafty-----CRAFTY!!! Gotta hand it to you...you got me.
05/16/17 10:52 PM
Is this spam that basically copied another thread to stealth itself to get clicks or something?
Ninja187
Ninja187's Gravatar
05/17/17 12:41 PM
This was my original post from another thread. Got it figured out, no spacers needed for fgrt207 and 310 rotors. For every 10mm larger rotors from the stock 310 you need a 5mm spacer. Do we dare click the link?
* Last updated by: Ninja187 on 5/17/2017 @ 12:45 PM *
05/17/17 3:53 PM
At least he put SOME effort into it.
