Romans, not bad for a ZX-14R, lol
Not Bad indeed,,,, what do think this beast will do with 15lbs of boost,,,, you know that's next lol
Koflaolivieri hope you can catch it on video too. Great work, cheers
Rickey’s bike still has stock internals right? And if so holly $H!T!!!!!
Cooter here is what is being made available.
Back to the bike, it only has a four pound spring in the gate and makes an actual 235hp on a very low compression motor. Just for correction, it made an actual 320 with 7 pounds on top of the gate, the actual boost was around 10 psi data logged. Our night at the track went fairly well, however we were face with typical new bike issues. I had a boost selenoid that was not grounded well and would not make positive boost. Then we dealt with tire spin also, and simply getting a new bike dialed and set-up for rider preference. If we can pull it off, we will test this week and get things sorted quickly hopefully. Thanks to Brock Performance for sending out a few clucth components that worked well. We used his2012 clutch kit with some bad ass springs, and simply put it worked flawlessly. Look at the 60 ft, and it held the power. I will be working on the bike this week, finishing small details. I will keep things updated, Thanks, Chris Jones.
Compresstion in a true (static) 9.6:1 c/o a set of custom CP Pistons, the head is stock w/ the exception of a set of heavy-duty springs. The new 14r head is a better port flow design, along with slightly higher lift on the cams. Don't ask me the numbers, but I measured them at one point. I just don't remember the exact numbers. But if memory is correct, it is in the .015 range more. The turbo on that bike is a custom Garrett gt-series w/ a billett compressor wheel. It has a 54mm inducer, that is legal for Real Street.
So...THAT means....Romes...you gotta do this
Boost is a given.
So...THAT means....Romes...you gotta do this....you'll have the fastest bike in Canada(if you don't already...which you probably DO)LOL!...think about it..
Grn, have you been drinking lol???? Fastest in Canada ??? dems some big shoes to fill. I have zero chance and I mean Zero. One can only dream.
