I wish I was Rook but the end of summer will be here before too long!
Bill you're right the suspension are soft! I went with the Ohlins shock and Fork internals but most guys running Racetech are sporting a big smile. Their rebuild is cheaper than buying Ohlins and possibly as good. If you can swing it I'd get their shock (it's in my signature) but for the forks, I would go with the Racetech rebuild if it's cheaper. I would give you pricing but I have been looking for my receipt and can't find it! I bought the shock for about $900 if memory serves me correct, the front rebuild should be around 300 but I believe that for the price of the shock you can get both rebuild with Racetech components.
The big advantage of getting the shock is the remote adjustability. That being said I have never touched it, when I ride by myself I need a harder setting and when I have the wife (130lbs she claims! LOL) I ride a little slower and the same setting works fine.
