Thread: frame sliders/bodywork protection?
Created on: 02/26/12 04:56 PM
jpooch00
02/26/12 4:56 PM
Anybody here able to recommend sliders & protection for the 14R?
speedfreak57
speedfreak57's Gravatar
RE: frame sliders/bodywork protection?
02/26/12 11:28 PM
Muzzy frame sliders, simple install and IMO good looking on my black 14r!
Black ZX-14R... to be turboed..
jpooch00
02/27/12 4:26 AM
Hey, thanks SF57!
So no cutting holes in the body work to make the Muzzys fit?
* Last updated by: jpooch00 on 2/27/2012 @ 4:26 AM *
Neilp
Neilp's Gravatar
Brisbane, Australia
02/27/12 4:54 AM
My Muzzy frame sliders dont fit, they are to tight around the black plastic shroud by the goerge foremans. I am having 5mm machined from the side of the alloy section 40mm long to clear this. I will take photos when I get them back.
Neil
speedfreak57
02/27/12 9:14 AM
I bought mine direct from muzzy and they fit perfectly, no cutting no nothing. The bolts were kinda hard to get out of the bike in the beginning because of all the res lock tight on it but once I got both sides off install was a breeze. If your doing it yourself make sure to thread in carefully an not strip anything because then it turns into a nightmare
jpooch00
02/27/12 4:08 PM
I just wanted to thank everybody who took the time to post their answers & opinions on my thread. I really appreciate it!
* Last updated by: jpooch00 on 2/27/2012 @ 4:09 PM *
Trc
Trc's Gravatar
03/06/12 10:50 AM
my local shop had muzzeys in stock and there pussy air tools couldn't break the bolt loose.
If you weren't there for my struggles, don't expect to be here for my success.
03/07/12 2:46 PM
LSL sliders are expensive but they are designed specifically for each and every model they make a slider for. They have a vinyl pad which cushions the initial shock and also inhibits spinning of the bike as it slides. Has 2 mount points so there you have another frame crack protection feature. The pucks and the brackets are extremely light. The friggin bolts are where all the weight comes from. I'm estimating ~2lbs.
A lot of folks prefer to go without sliders because no matter what you get, the brackets are so long they exert a great deal of leverage on the frame and bust it quite easily (so they surmise--I have yet to hear of anyone complain that their frame broke from sliders). Some have soft metal bolts and others are made to break before the frame would---good ideas but possibly going to fail in the process of saving the frame.
* Last updated by: Rook on 3/7/2012 @ 2:49 PM *
hagrid's Gravatar
03/07/12 4:36 PM
Do you use LSL Rook?
Yoshis!! GO NINJEE!!!
darryle
darryle's Gravatar
03/07/12 5:16 PM
I thought frame sliders were only good for a tip over,in a moving crash don't they do frame damage?
Black1
03/08/12 3:44 PM
Yup like Rook said. GSG's are quite expensive I know they use them for the track. Thank god I only had to use them once on my ZX12 but with that being said. I have GSG's on all my bikes and they tell me that they will have an answer for me next week on the ZX14r.
03/08/12 5:28 PM
I have a set of LSL sitting here. HAve not gotten to installing them yet.
From what I have heard, that is a possibility. The 14s fairings are very deep and require some pretty long sliders to reach out far enough. I have read of owners who avoided a lot of damage by using sliders as well. I'm sure it depends a lot on the brand of slider and also how rough of bumpy the pavement is.
I'm sure a garage tip over could bust the frame because if sliders just as well as a 130 mph track lowside. It's a gamble no matter what you do. The fairings might take the brunt of the crash but they may shatter or they may burn down to nothing.. The only sure defense is to not crash.
that has worked for me so far, thank you God.
* Last updated by: Rook on 3/8/2012 @ 5:30 PM *
hagrid's Gravatar
03/09/12 3:35 PM
Copy that Rook. Rubber side down.
privateer's Gravatar
03/10/12 8:19 AM
I just sold my Militant Moto Barrier Bars to a member. They are the cats meow of slide protection.
If you put sliders on the rear wheel, and Barrier Bars on the front, you can lay it down (please don't, just saying) at 20 mph and it will just take metal off the Barrier Bars.
I'm not even sure how easy it is to get them anymore, but they are beefy, light, mount in 4 spots, and you should google them and see them, because nothing else comes close.
Living the Gypsy Life
