Got it fixed now!! Shows you how much I have been able to ride in the last two years!
I bought a set of Lang thread restoring taps an dies.
Me:
I think when I do this, I might try starting the tap from the inside of the battery box where the threads are probably less damaged.
The plan I had to start the thread restoration from the back of the hole didn’t work. The tap was hitting the inside off the battery box and I was afraid it might go in cross threaded. I lubed it with with 3 in 1 oil and started it in from the outside of the hole. The tap seemed to go in perpendicular to the surrounding surface. I turned it in two turns and then backed it out a half turn repeatedly.
I removed the tap several times and washed it in mineral spirits to remove the metal shavings that came out. I also swabbed the bolthole out with Q-tips.
I applied 3 in 1 oil and threaded the tap in again until the tap felt smooth. The threads still look a little beat up but a bolt will go in and it doesn’t even feel loose.
I used LockTite on the bolt but if there is a problem with it coming loose, a little longer bolt should solve that problem. It was probably a good thing I was not able to start the tap from the back of the hole because there are at least 5 mm of untouched threads there.
Hub:
The loctite may have taken up a thread pitch angle, where you more or less had to thread the first winds like a needle, meaning, to line up the compound taking up the thread grooves. So the initial cross-threading kept the new pitch cutting a new groove over the original threaded hole.
Say if you first cleaned the old compound out of the threads with a tap, used fresh locker again, maybe it would have gone in fine. When I use locker, I run the drop way back at the threads so the initial beginning threads of the bolt and hole are clean and the drop of compound is not filling the whole hole.
Yes, I think that is the safe way to do it with the thread locking agent...if possible, apply it to the female threads below the beginning threads. That way, the threads at the top will be the correct threads and if the thread locker has established its own pitch, it doesn't matter. The bolt has already been started on the correct path and will carve through the old thread locking agent. Either that or use a thread cleaning tap and get the old LockTite out. I doubt many people bother to do that.
I will try this in the future. Thanks, Hub.
Could have been the bolt just went in crooked? IDK...this seemed to get progressively worse over two or three installations of that same bolt. Oh well, fixed now. This is one you really need to use thread locking agent on. The old dried thread locking agent seems to keep the bolthole tight for many uses but obviously that is no advantage if it establishes a thread that does not match that of the bolthole.
Me:
maybe the white film IS locktite. ?
The white residue is just old LockTite. You can see that from the last pic. No corrosion just some kind of weirdness with the threads of the bolt or the bolthole.
* Last updated by: Rook on 8/27/2019 @ 8:17 AM *
