Cool...
That says:
A. Rings ~ Puffs all day long. Can smell smoke, obviously; see it too.
B. Valves ~ On lift only. That means, you come up to a stop, take off, she blows out a little. Brisk ride [oil level and all that is fine] you lift on shutdown, then throttle back up she smokes? You might have dry valve guide seals. Though, this has to be severe wear for the new seals to be installed, no measuring and all, meaning. Then, she keeps puffing on lift = Valve Guides are too warn for new seals even!
C. Oil level ~ Based on my experience, based on drag's vaporization, based on the brisk, the oil level [in question], the leveling there of, I would have to conclude the bike was never abused. Add the sitting, the level, the brisk...
... From my seating position, my guess is we are not complaining about equal power between bikes. No power loss, meaning, right? Just a little oil bladder barfing at this brisk event. Unless we see more puffing, which it seems you do not, I can only guess a slight purge as per designed to do.
This is an air pump, so if you cannot seal the air, out the:
1. Exhaust valve ~ But, we are not having a power loss or excessive valve guide sucking = Burning will the PAIR do it to it.
2. Intake valve ~ Whereas the intake suck will burn in the cylinder chamber. This is a constant suck, so if it is burning slightly, it can call the ball on both guide leaks. Therefore, no blowing of smoke on lift are the guides.
3. Rings ~ Back to the air pump. If that thing can suck with the rings sealed, then it can suck oil if a ring is broken. That push of air or the compression stroke is saying, I can hold air, we have no loss of power between bikes. If I could not hold air, I'd push that air into the crankcase. With that speed, I can push more air from that one cylinder as the rpm rises, so the crankcase pressure rises with the rpm, but this is not happening either or we'd lose oil and you windshield would be peppered if you stay close enough.
With that said, both of you take and hold each others bike upright. Note where your level is and the level in question. If his is too high against yours????
* Last updated by: Hub on 6/5/2012 @ 12:31 PM *
