Thread: Battery terminal cleaning
Created on: 12/06/10 08:24 PM
12/06/10 8:24 PM
Pretty simple but if you haven't looked at your battery in a couple years, might want to do this well known procedure.
Remove battery and apply a mixture of baking soda and water to battery terminals and positive and negative lead wires. Rinse terminals with water after the baking soda solution stops foaming. This is the third winter I am going into storing the 14 and I see the negative terminal is pretty crusty. Positive not bad but I did that one and the + & - connectors.
Before
After
Everything should make good contact. Battery is still working fine and holds a charge for a long time.
RE: Battery terminal cleaning
12/07/10 12:44 AM
alg8er
alg8er's Gravatar
12/09/10 11:04 PM
Rook; slather those terminals inside and out with some petroleum jelly, and they won't corrode again.
12/10/10 5:37 AM
I use dialectric grease on all my ternimals
alg8er
alg8er's Gravatar
12/17/10 11:44 PM
"I use dialectric grease on all my ternimals"
Ooooooh........ fancy schmancy!
03/14/11 12:45 PM
Thanks. I have some dialectic jelly. I have started to use a bit on all the connectors I take apart. Got the battery jelled up a little bit. I knew I should have spent a extra dollar and got the big tube.
