Thread: C14 Center stand on ZX14
Created on: 01/08/12 04:20 PM
azzx
azzx's Gravatar
01/08/12 4:20 PM
I bought a used C14 center stand for my ZX14. Everything works except the spring hookup.
on C14 the springs hooks up is on the left side. It looks like on the ZX14 the spring hookup is on the right side.
Besids re-welding the spring hookup nob on my C14's center stand from left to right, are there any other "easy" ways to make this happen?
thanks
* Last updated by: azzx on 1/8/2012 @ 4:21 PM *
2015 ZX14R, 2008 Concours 14, 2007 zx14, 2000 ZX12R, 2015 Can Am Maverick Max
Danno's Gravatar
Southwestern Illinois
RE: C14 Center stand on ZX14
01/08/12 6:47 PM
There is also a small plate that bolts onto the frame with 2 8mm bolts that catches the top end of the spring. You will need that, the correct spring, and a tang welded onto the stand at the right location to make it work. The bracket is part #11054A Bolts (2) are # 92153B You'll also need the rubber bumper #92075
http://www.bikebandit.com/houseofmotorcycles/2007-kawasaki-ninja-zx-14-zx1400a7f-us/o/m10053#sch446089
* Last updated by: Danno on 1/8/2012 @ 7:08 PM *
