Thread: Z1000 Ninja handle bar base fit a zx14r?
Created on: 06/22/14 07:40 PM
doubleD
doubleD's Gravatar
06/22/14 7:40 PM
I've been comparing the 2012 Z1000 Ninja's handlebar base to my ZX14r. They use the same Rod and screw that connects to the base.
The Z1000 Ninja is $94 at bikebandit and the Base mounts differently.
I also wonder if the Fork circumferences are the same?
Anyone have the same thoughts?
* Last updated by: doubleD on 6/22/2014 @ 7:44 PM *
fatsix
fatsix's Gravatar
RE: Z1000 Ninja handle bar base fit a zx14r?
06/23/14 6:48 AM
Hunh?
2012 ZX14R CSB
TRAILBOSS
TRAILBOSS's Gravatar
06/23/14 9:16 PM
I think he means Ninja 1000...
2016 ZX-14R SE ABS (Harambike) - Brock's Ti Dual CT, 2WDW Flash, double bubble windscreen, Givi Tanklock 15L with 12v outlet, SW Motech Quick-Lock Evo Contour rack with Givi V35 bags, SW Motech tail mount with Coocase Wizard top box, KAOKO cruise control, fender eliminator, Vortex rearsets, Vortex V3 fuel cap, Vortex spools, Stompgrips, PSR SBK passenger pegs, Helibars risers, R&G radiator guard, frame plugs, Starrotors 55w 6K HIDs, Brembo MC/Rotors/Calipers, braided steel brake lines. 204hp/120tq
2013 ZX14R (Mjölnir)- Brock's Ti CT Meg, 2WDW Flash. 202hp 119tq. RIP
2008 Kawasaki ZX-10R trackfighter - Yoshimura R55, PCV, Servo Eliminator, Traxxion AK20 Cartridges, Penske Triple Clicker shock, EBC HH pads, Pirelli Superbike SC2 slicks, custom subframe, RSV4 tail, Ignition relocate, KX450F number plate, Apex adjustable clipons, CRG levers, Lever guards, Vortex rearsets, Stomp Grips, XT Lap Timer. 188hp, and not as much tq as the 14R!
fatsix
fatsix's Gravatar
06/24/14 6:14 AM
1000 makes more sense. I did a little reading. You need 28mm of fork to clamp on to. They are 50mm diameter, so they should fit. People love or hate the bar angle. It might be an option worth looking into if that's what you want.
Its a damn shame that no other rear set mounts interchange with the 14. I should make an adapter plate so i can use other brands, not to mention i'm going to need the plate to put the pegs where i want them beyond the adjust ability of the pegs. Longer shift rod....
* Last updated by: fatsix on 6/24/2014 @ 8:49 AM *
2012 ZX14R CSB
doubleD
doubleD's Gravatar
06/25/14 3:04 PM
I had a 1986 Concours and a 1989 ZX Ninja at the same time. I upgraded to 87 Concours handlebars (higher) and used the 86 bars on the Ninja, a direct bolt on. The cables and hoses fit. I had a more comfortable riding position on both Bikes.
This is a photo of the 87 bar on the left and 86 bar on the right on the Ninja.
Thanks for the information about the Ninja 1000.
* Last updated by: doubleD on 6/25/2014 @ 3:11 PM *
