Hi everybody, new on the forum (although have been reading it for a year now) and decided to turn to the gurus here for some advice. Hub, Rook, Grn14 et al. Your opionions are thus requested :D
Its still winter here in Finland but I'm starting to get ready for the spring in good time ;) so I'm doing some maintenance work and some digging on some of the issues I had last summer with the bike. . .
First of all, I think there was a variation on the idle speed of the bike with respect to air temperature or engine (coolant) temp. When the bike was first started in the morning it would start the auto fast idle sequence normally everytime and eventually when the preset coolant temp was reached it would lower the idle to the preset normal idle, but always a bit lower (<1000 rpm) than normal spec idle. Then after a long ride when the engine got hot (4-5 bars on the display) - especially on a hot day - the idle seemed to get higher, enough for the clutch to spin the transmission so that the first gear would engage violently like KRRRR CLANK!!! Always with a cold engine the first would go in very nicely, only a minor clunk from the trans like my previous bikes not like its gonna explode.
I know having read that the idle speed is meant to be set when the engine is hot to 1050-1150 rpm but is there supposed to be such a high variation? And if I were to set it to spec 1050 rpm when hot I'm thinking that it might drop too low when cold. So far stalling hasnt been an issue even when cold, I dont remember it stalling ever. Is it possible that since the bike is still almost new (7450 km on the odo) and taken out of the crate last summer, could this be a normal breakin symptom that its still a bit tight and maybe the idle is set a bit high at the factory because of the breakin? Any ideas?
* Last updated by: ilarik on 2/29/2012 @ 5:47 AM *
