If you go out and you could carry only one thing with you, what will you take? What is it? What thing will you carry? Think it carefully. Yes, you get the answer, it is mobile phone. Today, mobile phone is not
only a communication machine, but also our computer, our wallet, our recorder, our camera, our Xbox, navigation system,our torch...... It could help us a lot in many ways. We opperate mobile
phones everywhere all the day, no matter sitting or walking or even eating. But wait a minute, everywhere? Can mobile phones be used everywhere? What to
do if we need a silent environment in some places? Now the problems occur, we can not use mobile phones too much. There are many places where mobile phone
is not welcome, these places includes cinema, conference room, library, law court, exam room,
restaurant and so on. How to solve the problem? The key is
mobile phone jammer. Mobile phone jammer, an anti mobile device, is a kind of electronic device that could
jam mobile phone signal issued by a cell phone tower. Once you turn it on, all mobile phones in its working range will show
No Service. But after we turn it off,
all mobile phones will resume working, it won't cause any harm to the mobile phones. To learn more about mobile phone
jammer, please come to our website. Here is a very popular mobile phone
jammer: 100 Meters Jamming Range 5 Band 70W High Power 3G mobile Phone
Signal Jammer, model number S805046. Ever consider that a
mobile phone blocker can block the
5 frequency bands CDMA GSM DCS PCS 3G at
the same time with powerful jamming distance? Then this100 Meters
Jamming Range 5 Band 70W High Power 3G mobile Phone Signal Jammer can
easily reach this goal and then you can have a look at the details of
it.
First since the standard equipped antennas of this mobile phone signal
jammer is 5PCS Omni-directional Antenna, which enable this mobile phone
jammer to cut off the signal from all the directions. Besides since
designed with 70W high output power the jamming distance of this mobile
phone jammer is really powerful, which is up to 100 meters depending
on the signal strength in the given area. Besides when design this
mobile phone signal jammer, the designer has taken the temperature into
consideration, so this high power mobile phone jammer is designed with
cooling fan, so that it can always keep in good condition and do no
harm to the jammer device itself. In this way this high power mobile
phone jammer can be used 365 days continuously to reach the nonstop
working goal.
Last but very important is that this mobile phone jammer owns the
adjustable design so you can decided the jamming frequency bands and
the jamming range all by yourself. If you are in need of one just come
here and pick up one to help solve your problem.
Features
It can continue working for 365 days with AC adapter
High power Jammer, total output power: 70W
External Omni-directional Antenna
Every band frequency can select output power
All the TX frequencies cover downlink only.
Automatic power switching power supply: 50 / 60 Hz / AC 100 ~ 240V
Jam all of mobile phone signals (3G/CDMA/GSM/DCS/PCS)
Best for blocking 3G signal
With cooling fan inside
Output power is adjustable
Jamming range up to 100 meters
Application Area: prison, guard, invigilate meeting room, library,
theater, class room etc
Technical Specification
Affected Frequency Ranges:
-CDMA: 851-894MHz 42dBm 15Bm/30KHz (min)
-GSM: 925-960MHz 42dBm 13dBm/30KHz (min)
-DCS: 1805-1880MHz 41dBm 10dBm/30KHz (min)
-PCS: 1920-1990MHz 41dBm 10dBm/30KHz (min)
-3G: 2110-2170MHz 41dBm 12dBm/30KHz (min)
Power supply: AC adapter (AC220V-DC27V)
Shielding Radius: (20-100) meters@-75dBm still depends on the signal
strength in given area.
Total output power: 70W
Weight: 13kg
Product Notes
Make sure to connect all the antennas firstly before the power supply
is switched on. Please do not take off antenna when the machine is
working.
Antenna shall be used vertically to the ground for working more
efficiently.
Please don't put the jammer in the bad Condition of over-wet, over-
hot, high voltage and high magnetism.
The jammer shall be installed in the position with good ventilation,
and large-scale things shall be avoided to ensure the shielding
effect.
The jamming distances we mentioned on website are for customer's
reference only. The actual jamming distance will be varied depending
on the signal strength and the use location and if full charges, etc
