I'm going to water/soap my tire beads. I'm going to lay the new tire on the rim, start to push it into the rim and by hand, I pushed on the one side of the tire by hand.
I now set the tire bead into the middle of the rim.
I now take one spoon, set it under the bead, grab another spoon, pull the bead over the rim and stop.
I then take the 3rd spoon, set it under the bead and pull out the 2nd spoon that was right beside the 3rd entered spoon.
I have the 1st spoon between my legs. I have 1st spoon and the 3rd spoon holding down the bead from backiing off the rim.
I take spoon 2 and keep peeling over the bead onto the rim and as I do, 3 spoon is removed, is now dug under #2 spoon's side following the bead-bend-over.
I have 3 spoon in and pulled 2 spoon out.
I have been pushing the [tire] already over the rim: is to keep pushing the carcasses into the center as you keep feeding bead. Why? This moves the bead on the outside easier to peel over the rim is it makes it longer on that one end. See it?
I then see at this point that the less distance from 3 spoon is the better bending over a smaller bead bite, not send spoon 2 farther away from stationary spoon 3. Why? See how too much pullover is a fight with bending the rim with too much bead?: whereas, I peel over short beads next to the 3 spoon, the tire goes on easier.
I am toward the end. Spoon 1 never left that first position under my crotch. Spoon 2 is pulled, because the tire is about to be hand fed from here on out.
I am always pushing carcass sides into the center as I push the tire into the center at the same time.
I pull all spoons and pop the tire on the rest of the way.
___________________________________________________________________________________
All this time it was pretty much a thick soapy mix around the beads so less runs into the rim. My (yellowhite?) painted dot is lined up with the schrader plug.
I'm pushing down on the tire so the beads pop up more or less even not cocked. Does not matter really.
I now pull the schrader valve out, add the air and let the beads pop twice. One pops on the one side, and do not fear adding more air to pop the other side.
I hear that last pop, I pull the air hose off the plug, let the air escape, install the schrader and check air pressure.
Balancing is the next step.
I take all the collars out of the wheel, install the wheel alone and slide the axle in place. The bike is the balance stand.
I spin the tire and walk away.
I made my mark at 12 o'clock, spin the wheel again so I know the mark is back to being straight up again, I found the heaviest spot, which is the bottom, obviously.
I install the weight back on, move the wheel to 3 or 9 o'clock position, let it go, see if it returns to the top?
I want a balanced tire to stop no matter what clock position. Then I know it's balanced.
