I used "Bel Ray Super Clean" at first. It leaves a white tacky film, and is somewhat thick. It dries in about 10 minutes. Not bad, but not best...
Then, "PJ1 Blue Label". It is also thick, and leaves a tacky film, but it dries clear. I like this one, but it does collect dirt and grime on that tacky film.
Now, I'm using "Liquid Performance Premium Chain Lube", the WebBikeWorld.com top pick. This one is best for me, it dries to a thin film that is not tacky. It dries in about 15 minutes to a thin, clear film and lasts a very long time. Does not collect grime. Spray on, wipe off excess. Has a teflon derivative in the formula.
For chain cleaners, I started with "Honda Pro Chain Cleaner". It works well, but requires a water rinse (most of these do).
I switched to "DuPont Motorcycle Degreaser" in the aerosol can and has 2 "episodes" in a row with the cans emptying themselves all over me and my property upon first use. I pushed the button, and they spewed their entire contents out with me frantically attempting to figure out how to stop it (I never did).
I liked the chemical itself enough to give the liquid in a bottle a try. This is great cleaning stuff and does not need a water rinse. 16 oz. bottles last a long time. I use it for all my chains now. Dump some into a bowl. Brush on with a chain "grunge brush", wait 10 minutes, and wipe off. Dump remainder back into a glass jar. Save for next time. Then apply chain lube.
Last, I apply the lube with a Grease Ninja. This little gem applies the lube to just the chain, keeping it off my tires and rims. Its a nylon part on the end of a large diameter copper wire. It uses spray can lube (yeah, lube cans dont seem to detonate on me), and attach to the can nozzle through a long thin plastic tube. I also hold the wire to the can with a large auto screw-to-tighten hose clamp. Put the Ninja on the chain, spin the wheel, push the button. Voila, chain is lubed and nothing else! Nice...
Newspaper tarp gets folded up for next time. Done.
