Thread: DFI F1 Code
Created on: 04/06/17 11:21 PM
Zx14Visuals
Zx14Visuals's Gravatar
DFI F1 Code
04/06/17 11:21 PM
Recently my bike has been filling up with oil in my air box. Once i cleaned it all out, drained the oil, and replaced. I pulled my spark plugs because the bike wasn't turning over. Gladly i replaced those thinking all will be good. nope fuck me, My F1 code pops up , now the manual says that it is the Digital fuel injection system. My battery is brand new. any ideas on how to fix this ? or would the shop be the best option ? thanks
RE: DFI F1 Code
04/07/17 6:11 AM
If you have a PC5 or Bazzaz, the pins in the connectors could be bent. Did you disconnect that?
Are you sure the stick coil wires are connected/pins are straight?
A bent pin can be very hard to detect visually without magnification. A 14 running on 3 cylinders may not sound or run much weaker than all 4 under normal street riding conditions.
Nightmare
Nightmare's Gravatar
RE: DFI F1 Code
04/07/17 6:53 AM
If memory serves me well this morning, the F1 code is more of a generic "it be broke" kind of code, turn the ignition on, hold down both buttons and it should flash what the actual error code is.
There are a number of wiring harnesses under the air box and it's entirely likely that you may have accidentally disconnected a loose connection. Hopefully the error code helps direct you to the issue, if not grab a really good flashlight and a take your time checking the top area of the engine to find all of the wiring harnesses.
RE: DFI F1 Code
04/07/17 8:47 AM
If i'm not mistaken,oil in the airbox(at least as much as you say)is evidence of overfilling.I've had that.Even Brock has had that.you ride your bike like you're at the drag strip?
* Last updated by: Grn14 on 4/7/2017 @ 8:51 AM *
Zx14Visuals
RE: DFI F1 Code
04/07/17 10:54 AM
Yeah i have a PCV but all pins are good. And on the oil over fill, it could have been , i only put in 4 qt when i changed the oil ,but once i tried to take off the filter we had to use a pipe wrench. As good as i can see all my wiring is connected, im gonna go try that double button and see if i get the issue to pop up
Zx14Visuals
RE: DFI F1 Code
04/07/17 11:02 AM
Shows error code 31
Fordtech
Fordtech's Gravatar
RE: DFI F1 Code
04/20/17 5:04 PM
Just checked on code 31.....vehicle down sensor. Not good!! There is a reset for it.
Just looked at the post date...figure all is good now....
