Hi All,
I did a quick search and was not very successful, so I figured I would just post the question.
I sent the following question to AreaP because I have AreaP pipes on my 14.....
Hello,
I purchased my current bike "used". The bike has approx. 2,700 miles on it. I was finally able to get it out on a ride (due to weather) and noticed popping (almost like a back fire) on decelleration. I doubt any other mods were done with the exception of your pipes. I am looking for a recommendation to correct this? I know I can add a power commander, but I have not had very good luck with them in the past. Will the popping hurt anything?
They responded with....
Hello,
There are many things that can cause this. The easiest place to start is by plugging the fresh air hose from the airbox to the rebreather valve. This may lessen it. A PC3 can help, but may not eliminate it completely. It is actually fairly common on most less restrictive exhaust systems for the ZX14. Most any of the ZX14 forums will have a pictorial and step by step for this modification.
Sincerely,
Area P, Inc.
Silent Sport N.A., Inc.
1240 Simon Circle, G/H
Anaheim, CA 92806
Ph - 714-630-2386
Fx - 714-630-2422
www.areapnolimits.com
So.... Any ideas? I know popping (or backfires) are due to an air/fuel mixture issue. Even if I do attempt a PC3 (which like I said I have not had good luck with on previous bikes (2001 Blackbird & 2006 Hayabusa) which MAP would I use? Also....realistically, would plugging the fresh air hose do any good?
