Hey all-hope everyone's safe and sound! Thought I'd share a possible issue with the front fender.I would say every once in a while check your front fender mount area-especially the connection where she mounts up to the vertical bracket to the rear of the fork tube(on both sides).I recently was cleaning my front wheel and happened to look at the fender there-the plastic had cracked and separated from the mounting bolt,and also created an approximately 2" vertical crack upwards towards the top of the fender.The place where it was separated had pulled inward about 1/2".I can only think this was caused by incorrect tightening of the mount bolt(too tight probably)I had tightened it myself a while back(both actually) not thinking that I may be stressing the plastic under the bolt fastener(the metal eyelet).I remember while riding a while back that I heard a LOUD POP,but brushed it off as a rock or something.You guys might want to check your torque settings on those.Stay safe all-have fun!!
