Thread: electronic limiter
Created on: 11/05/09 09:27 PM
darkwatch
electronic limiter
11/05/09 9:27 PM
how do you get rid of the governator / limiter that keeps the bike from going over 186mph. and what is safe to do so without causing more problems??
i read some of your guys post.. good info .. glad to have joiined this forum.
* Last updated by: darkwatch on 11/5/2009 @ 9:32 PM *
scottjkyl
scottjkyl's Gravatar
RE: electronic limiter
11/06/09 6:56 PM
http://www.zx14ninjaforum.com/messages.cfm?threadid=6C778567-D56B-84E2-17C1CBCB2BBFBFB1
11/06/09 9:31 PM
Also heard a while back that there was a way to disable the limiter by grinding off the points on a nut on the front sprocket shaft. Haven't heard about this for a while. Recently read about same mod for busas. It is very inexpensive to replace the nut.
11/06/09 10:59 PM
you'll lose your gear indications as well.
BadinBlack
BadinBlack's Gravatar
11/07/09 8:12 PM
I use a speedohealer V4. The 14 is restricted by the speedometer, and the speedohealer has 2 settings you can switch between with the push of a button, one lets the speedometer read accurate, and the other makes the speedometer read low so you can bypass the limiter. The best 109 bucks I ever spent
darkwatch
11/07/09 9:44 PM
thanks for all the info . i'll check it out..
