I usually hear about "turbo" on bikes but not "super."I was not exactly sure what the dif was.
Oh, ok, common misconception. As a rule, a supercharger (there are two basic types) is driven by a belt or gear off the crankshaft. It provides boost quite early in the rpm range, and doesn't need an intercooler as much as a turbocharger.
A turbocharger is still a compressor, just like a supercharger, but it is driven by exhaust gas pressure. So the more rpm you have the more it boosts, and it often takes a while to build boost which is referred to as boost lag.
Like I said, I have seen show bikes with superchargers, and you wouldn't want to run one on the street because of the weight and change in center of gravity and probably width of the bike. A turbocharger will easily tuck in front of an inline 4 engine since you are removing the header anyway in favor of plumbing to route exhaust to the turbocharger drive input.
With turbochargers, you often need an intercooler because you are pumping hot exhaust gas into an impeller drive which has a air charge impeller wrapped around it, so a lot of heat transfers into the air charge before it reaches the fuel injectors or carb(s).
I've seen many superchargers in carb applications with the carb sitting on top of the charger. I've never seen that done with a turbocharger, which doesn't mean it hasn't been done. Heh.
Living the Gypsy Life
