Hey again...
I'm thinking of starting to 'improve' on my ZZR1400/ZX14 for the next summer. Slipons would be my first mod. Reason would be not the usual one, since it has enough power (and torque, even though low end is 'soft' compared to busa, but still enough). The reason for me to consider slipons is twofold, sound and HEAT. I know, what a looney, doesn't care about power, right
But seriously speaking, since the gen2 zx14 has THREE cats meaning one in each muffler and one in the collector, the heat is really getting to my nerves and I was even thinking that maybe since the cats warmup to several hundred degrees celcius, even the engine heat may be affected!?! So if I were to just get rid of the original mufflers and install Leo Vince EVO2 Euro-approved slipons, see http://www.leovince.com/en/catalog-kawasaki/terminale_ovale_omologato_evolution_ii_passaggio_standard_zzr_1400_i_e_2008/10564 and just leave the oem headers and thus fuel mapping to stock (no PC3/PCV!). If I have understood correctly this would greatly help the exhaust heat since two of the cats would be gotten rid of and still the bike would be in fully road legal and also the warranty should not be affected since the fuel mapping would be unchanged (Leo Vince claims that the mufflers are developed for the stock mappings!), I will of course confirm this fact from the dealer before installing (or having them install the pipes...since its under warranty).
Also the the second point would be purely aesthetic, the sound. The oem mufflers are SILENT, there is no sound coming from them. Now I like my bike having reasonable sound levels so that I don't have to wake up the neighbours when going for a night ride, but still that thing is so quiet that every little tick from the engine gets so much presence, maybe I'm 'hearing noises' ... ... but seriously, the it sounds 'unbalanced' since the engine isn't 'silent' but the mufflers are, it just doesn't sound good to me. Opinions are appreciated from you who still have oem mufflers (or slipons for that matter) does your engine 'tick' when warm, I mean relative to all the other bikes which have solid valve lifters, like the gixxers, busa, fireblades, blackbird (surprisingly quiet that one...) etc.
Currently it is in entirely stock condition, so the only 'improvement' I have done so far is adding a tank pad and strapping the tipover sensor so that it wouldn't rattle (thanks everyone, btw for that clue...). So the very next thing is (see previous thread if interested) to lower the idle speed to spec 1050 rpm when HOT, so that the 1st gear would engage nicely (higher idle => higher trans main shaft speed => CLUNK), this seems to be a simple fix and IMO should be kept to a closer eye on scheduled maintenance at the dealers too. Problem solved.
