Lets walk this thru from start to finish so we see matter in its 3 forms and a flow of air dynamics:
You know I'm not schooled in any way so it's not going to be all scientific with the proper rules applied. We start with the basics and see who is doing what:
Crude ~ That's pretty much black and is a solid.
Gasoline ~ That's this crude, distilled and processed into a liquid.
Ex. Gas ~ That pretty much sums it up as in a gas.
The next step is to look at the rules or laws of, 'you cannot create or destroy matter.'
The next step in the thought precess is, 'for every action-react, there is an equal and opposite, because you know the gas is moving out the port in a straight shot, but it's so supersonic in the reverse movement, that it moves up the blockoff caps. And that's where the opposite comes into play as that hot liquid/gas/solid, licks and sticks on a surface, or since you cannot destroy that drop of liquid energized to a gas, then back to a solid, it's going all over the place.
As you can see, the PAIR is more like a cutting torch or say if we turned off the accy, left the oxy burning, the oxy alone will continue to burn. Rocket fuel is LOX or highly condensed liquid oxygen. The next step to think out is I am adding oxy thru that PAIR hose. It's simply means, no acetylene needed, the flame will light the oxy up, which adds more air think.
The next step to think is 10/10 or 10 degrees before and 10 after top dead center (TDC). I spark @ 10 BTDC>>>>>>>---@ 10° ATDC-----, My bang after bang >>>> pushing that piston down, I cool off after so many degrees---- back to a hot gas. I need Oxy to enter and reignite the hot gas or flaming out gas. The next step to think is the playing out of oxy at the closed chamber. That backwards kind of effect is here is more oxy @ PAIR. This WAS reheating the cooling off gas or flaming out; which is the lack of oxy; which for every action; the lack of PAIR meeting the reversion; the cannot create or destroy matter; the matter clings to the bottom of the cap.
The next step or thought is to think how PAIR is one big street sweeping brush and how clean that one port looks. Then, the next thought is, I may have swept the carbon away from sticking, but I cannot destroy it so it is down that pipe cooling off and licking on the walls of the valve/port/PAIR chamber/header/collector/cat/muffler/tip/atmosphere: you cannot cause one drop of matter to disappear even into the thin air.
