Thread: numb hands
Created on: 04/04/14 01:13 PM
Nastynotch
Nastynotch's Gravatar
numb hands
04/04/14 1:13 PM
Ive been riding on the street since I was 20 (36 now), and no matter what kind of bike im on within 30 mins my hands go numb. Ive experimented with all types of loose grip, different hand positions on the grips ect. Nothing helps whatsoever. Anybody else have this problem? Solutions?
2013 ZX-14R SE
2 Wheel dyno works flash
Muzzys black stainless slips
V1 custom mounted
Zero Gravity DB screen
Yoshimura fender eliminator
Black powder coated wheels
Cornelius
Cornelius's Gravatar
RE: numb hands
04/04/14 1:18 PM
Gloves? Squeeze the tank tighter with your knees?
Nastynotch
RE: numb hands
04/04/14 1:22 PM
Yea I always wear full gear, but that's something I haven't tried there. I usually rest all my body weight on my wrist
2013 ZX-14R SE
V1 custom mounted
RE: numb hands
04/04/14 1:27 PM
"I usually rest all my body weight on my wrist"....there's your deal.Use your torso(knees) to lift off the bars...a throttlemiester will also help to give your wrist a rest.A light touch on the bars will work...the frontend will track just fine.Except on rough road surfaces...but otherwise.The bike will actually handle better getting that weight off the bars as well.
You can practice gripping by removing your hands completely from the bars...and using your knee grip to hold your torso up a bit.This is where a throttlemiester shines;)Holding a tight grip in any manuever will restrict the frontend's ability to compensate for tracking.You don't want to have that happening.It should track on it's own,with mild inputs to the bars.Having a throttlemiester will allow you to rest your hands,fingertips on the bar ends...and gently push in the direction you want to go.
* Last updated by: Grn14 on 4/4/2014 @ 1:35 PM *
Nastynotch
RE: numb hands
04/04/14 2:20 PM
Thanks for the input man. Going to look into that this evening.
2013 ZX-14R SE
V1 custom mounted
RE: numb hands
04/04/14 3:18 PM
These gloves,or ones like them are made for carpal tunnel etc ...
LINK HERE !!!
Also heavier bar end ? In addition to body, hand position can help ....
* Last updated by: carabuser on 4/4/2014 @ 10:07 PM *
RE: numb hands
04/04/14 3:33 PM
Love your link Cara...yup....definitely remove the pain;)
hagrid's Gravatar
RE: numb hands
04/04/14 3:38 PM
Lol... I see it Montana.
I'm guilty of death grip. I have to concentrate on relaxing; tough to do on a Ninjee sometimes.
Yoshis!! GO NINJEE!!!
Nastynotch
RE: numb hands
04/04/14 4:02 PM
I prefer scotch myself...neat
2013 ZX-14R SE
V1 custom mounted
NeedForSpeed
NeedForSpeed's Gravatar
RE: numb hands
04/04/14 5:50 PM
You might try a set of these: Your text to link here...
Easy install, 4 bolts and that's it for my ABS model. I think on non-ABS there is some sort of brake line relocation that has to take place, looks pretty basic. Instructions are on that link.
I put them on my 14R right after I bought it. Being hunched over too much can cause you to put too much weight on your wrists causing numbness.
YMMV
* Last updated by: NeedForSpeed on 4/4/2014 @ 5:51 PM *
'99 XX, '12 ZX10R, '13 ZX14R, '16 701 '17 FZ-10 - life is very good!
It's the journey, NOT the destination!
RE: numb hands
04/04/14 10:09 PM
Doh ! I put the wrong link in for the gloves !!!
Here is the right link, also fixed the previous reply ..
LINK TO GLOVES !!!!
RE: numb hands
04/04/14 10:46 PM
Well...if those gloves don't get it....there's always the wine;)
RE: numb hands
04/04/14 10:50 PM
Your right Grn, Wine a little, you'll feel better !!!! Ha Ha !!
Oh, by the way, love those Vance and Hines pipes you have, they started with a little shop right down the street
From where I grew up and still live.
Unfortunately, CA extortionists, fined them $500,000 for EPA exhausts, but they are still going ...
* Last updated by: carabuser on 4/4/2014 @ 10:56 PM *
RE: numb hands
04/04/14 11:06 PM
Thanks Cara...been wanting to install these since two years ago.FINALLY had some midpipes that fit;)Still have my Yoshis...but these I like better.Actually the first set I've seen on a sportbike...other than the website pics.They're not very popular I reckon...not for the big Ninja anyway.But I like em...
When I ordered em...they said they would fit my 2012....they didn't.The midpipe was fabbed wrong....I put em up and got the Yoshis.Got my Akros Headers...added the Yosh midpipes..and tried the V&H's on there...they worked;)Was getting tired of polishing those Yosh's...great pipes...but black seems better....performance is at least on par with the Yoshimuras or Brocks...at least.
* Last updated by: Grn14 on 4/4/2014 @ 11:13 PM *
RE: numb hands
04/04/14 11:36 PM
I know what you mean about polishing the SS one, it's kind of getting old. I may go to some sort of
Carbon Fibre or black ....
RE: numb hands
04/05/14 12:25 AM
The thread kinda changed here a bit....but I think you can buy the outside canister in CF from Yoshimura.Then install...if you have the rivet tools and such.Just the outer sheath...not the inner part.
rod442
rod442's Gravatar
RE: numb hands
04/05/14 4:13 AM
After relaxing and not resting my weight on my hands and arms; the next easiest thing I found for helping with hand issues are these: http://www.grip-puppy.co.uk/
Grip puppies. They are cheap ($10). Comfortable. reduce Vibration. And Easy to slip on over your existing grips. Available from a bunch of sellers, ebay, amazon, etc. And absolutely amazing.
I have had hand surgery which has weakened some of my grip strength, and also results in making it hard to hold tightly to things for a long time. By having the grip puppies make the diameter of the throttle BIGGER; I don't have to squeeze down as hard. They really are amazing. and ten bucks.
* Last updated by: rod442 on 4/5/2014 @ 4:14 AM *
dericrey
dericrey's Gravatar
RE: numb hands
04/05/14 7:09 AM
I second Grip Puppy. It's just a simple slip on grip overlay to give you more cushion/ less vibration. I only ride with weight on my arms when I am in town 50mph or less (usually not in town long). +1 on grip tank with knees and have a light grip. It will cure the numbness, also ride everyday - its kinda like moto-exercising (for the body and soul).
2009 ZX-14
Semper Fidelis
Kill 'em all, let God sort 'em out.
Violence Solves Everything.
thebiglebowski
RE: numb hands
04/05/14 10:01 AM
i run the kuryakyn ISO grips. nice and comfy and look good in all black. https://www.google.com/shopping/product/10046959537977532092?q=kuryakyn+iso+grips+black&espv=210&es_sm=93&bav=on.2,or.r_cp.r_qf.&bvm=bv.64125504,d.cWc,pv.xjs.s.en_US.1ipquFBLRi8.O&biw=1517&bih=725&tch=1&ech=1&psi=gyhAU8SFJuy_sQSu5YLICA.1396713613221.3&ei=hihAU9eOCu3F0AH90YHwCw&ved=0CH0QpiswAg
2013 zx14r black/green SE
RE: numb hands
04/05/14 12:46 PM
3rd on Grip Puppies. My throttle hand used to go numb after about 20 minutes. Now I'm usually good for all day.
jtemple
jtemple's Gravatar
RE: numb hands
04/05/14 6:37 PM
Get your weight off your hands and relax your grip. Not only is it more comfortable, the bike instantly becomes more controllable.
ZXKawi
ZXKawi's Gravatar
Cedar Rapids, IA USA
RE: numb hands
04/05/14 7:12 PM
I have 2 sets of grip puppies sitting here, just haven't installed them yet. They are great, but you need to get the weight off your hands too!Put more weight on your legs and torso to support your upper body.
Nastynotch
RE: numb hands
04/05/14 7:50 PM
Well it looks like im gonna order these grip puppies and give em a shot. Thanks everyone for your input, much appreciated.
2013 ZX-14R SE
V1 custom mounted
Nastynotch
RE: numb hands
04/05/14 7:53 PM
Dericray, is see your from vidor. I live in lumberton we should go ride one day.
2013 ZX-14R SE
V1 custom mounted
PaulAB
PaulAB's Gravatar
Chicago Metro, Far North
RE: numb hands
04/05/14 11:47 PM
Numb hands? How about this fella with numb body? Yeah, its been a long winter.....and especially up int the Big Sky neighborhood. Looks like he's got that upright torso thing down good, but definitely needs some wired gloves!
