Hi all,
In the last 48 hours my bike has suddenly developed a misfire. I just thought I'd share my experience thus far in case somebody has the same problem.
It started off while I was riding, about 30 minutes into the ride the bike developed a misfire (read as: it sounded like a ducati with even less power). What was weird though, is that she only had the misfire when at low rpm, low throttle opening, or a mix of the two. When i was at WOT or in rpm higher than 4k the misfire cleared and the bike rode as normal. My first conclusion was that I must have a bad sparkplug.
So this morning I changed all the plugs (if your hands a larger than a toddlers, it's quite difficult), there was one fouled sparkplug to confirm my assumptions, I reassembled the fairings thinking all is well and took her for a test run. The misfire was gone and all was well, but low and behold, the minute she got warm enough for the fan to engage, the misfire returned. Quite angry about the situation I returned home and waited for the bike to cool down. 4 hours later she was 1 bar on the temp readout on the display and I decided to test my new theory of the problem being heat related. When the bike started the misfire was still there, i revved her once and the misfire cleared. Took her for a test ride and all was well until she heated up and the misfire returned again and once again if i opened the throttle beyond 4k rpm the misfire cleared.
I got home let her cool off and disassembled her again. The same cylinder that had a fouled plug, cylinder 3 in case it's relevant to anybody, had once again covered the plug in fuel. I the noticed what I hadn't noticed earlier, the coil pack (pencil coil to the more old school gents) had left a layer of oxidated powder on the top of the plug. I used a screwdriver from my precision set and inserted it into the coil and when I removed it, it was covered in oxidation (surface rust powder). After some research (Google is our friend), I found that this is a common sign of coil breakdown and that the solution is to replace the coil.
I phoned the local dealership, the price of a single coil is 1247 rand (ZAR if you wish to use a currency converter), I then phoned the local bike scrap yards to find a second hand unit. They did not have one from a Kawasaki, but did have one from another bike and "We're kind of sure it will work on your bike but we dont guarantee anything and won't be responsible for any damages etc". This left me with only one choice and that's to take the dealer part. I confirmed my train of thought with a few of my friends who are more knowledgable than myself and they all agreed with my conclusions. So I have ordered the new coil pack from Kawasaki and they say that it will be delivered to the dealership tomorrow evening.
I will post my findings with regards to if the problem was resolved or not.
* Last updated by: GuyBaulch on 11/11/2013 @ 8:44 AM *
Previous - 2006 ZX14 - Flies Removed, Full Muzzy system, DNA Filter.
Previous - 2007 GSX600R - Bone Stock
Previous - 1988 Suzuki 750
